Activity Forums Apple Final Cut Pro Legacy how to add Time code track using a movie’s time stamp
  • how to add Time code track using a movie’s time stamp
    Posted by Cheyo Masters on November 23, 2009 at 4:07 pm
    I have lots of quicktime clips created in differente cams ( canon 5d ii, handheld Hd recorder etc ) I want to create timecode track using the time the clip was created or modified? ANybody? Thanks
    Cheyo Masters replied 16 years, 10 months ago 2 Members · 4 Replies
  • David Bogie
    November 23, 2009 at 4:35 pm
    Timecode comes from the metadata attached to the video itself. For that, you just use the timecode reader.Or you can modify the timecode by applying timecode generator. If you want to super an arbitrary date, you do that with a text generator.
    bogiesan
  • Cheyo Masters
    November 23, 2009 at 10:02 pm
    I guess my question is how you add timecode to 300 files based on the date stamp.
  • David Bogie
    November 24, 2009 at 3:32 pm
    [cheyo Masters] “I guess my question is how you add timecode to 300 files based on the date stamp.
    I guess you will create 300 separate title supers.
    You could do it Compressor by using the watermark feature but you’re still going to create 300 separate text objects.
    The date of creation metadata item, white it exists, is not available as a selectable and then superable item, AFIK. There may be a filter/plugin for FCP that does that, dunno.
    bogiesan
  • Cheyo Masters
    November 24, 2009 at 7:31 pm
    Oh ok. haha. Man, I dont know the lingo. I was thinking, TimeCode track inside a quicktime files. The quicktime that gets read by final cut when importing a file. But yes Youare absolutly right. I just dint know how to explain myselft. Basicle create the timecode data…
    SImilar to going to Modify-Timecode inside final cut. Thanks though
