Activity Forums Adobe After Effects how to add sun to clean sky
  • Tudor “ted” jelescu
    May 12, 2010 at 7:49 am
    Not everything can be solved using a plug-in.
    Sometimes you just need to be creative and think a out of the box.
    I was not able to see the first example and from the second I get the impression that you want it to look like your shooting something under water from above the surface. However your description leads me to think that you want the lens to be wet… whichever it is, the following should work:
    You can shoot or buy some fx clips of water reflections over a solid color background (preferably dark)or (for wet lens) water on a window (flat glass surface). This will become your displacement map. Worst case scenario- use a high res still of water reflections. Tweak distortion (displacement) to get the right feel.
    Apply glow with wide radius to soften.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Steve Roberts
    May 12, 2010 at 9:42 am
    Search the COW for “caustics”. It might help.
  • Efi Or
    May 12, 2010 at 3:12 pm
    ok ill try.
    thank you.
  • Michael Szalapski
    May 12, 2010 at 7:50 pm
    Speaking of caustics…
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Alperen T. ayhan
    May 12, 2010 at 9:04 pm
    you are using fractal noise for them, there is a tutorial about it:
    https://maltaannon.com/wp-content/uploads/tutorials/after-effects/growing-3d-vines/video.flv
    In the middle of the tutorial you will see how reflections can be done..
    Alperen T. AYHAN
    http://www.sinamasal.com
    Always cinema…
  • Efi Or
    May 13, 2010 at 9:57 pm
    thank you all
