Activity Forums Avid Media Composer How to add something to a data track?
  • How to add something to a data track?
    Posted by Juan Juig on July 7, 2025 at 11:21 pm
    Hello,
    I have a transcript of a video that I turned into subtitles with timecodes that correspond to the original video. I have a .srt and .stl file that I can also convert to other file types.
    What I would like to do is add those subtitles to the original video within Avid. Not by creating SubCap on a timeline but rather I would like the subtitles to be present within the source file itself. So that when I match-frame the clip on timeline, the source still contains those subtitles, while they are not burnt-in into video.
    I was thinking whether it is possible to achieve that by somehow importing or embedding the subtitle file into source clip with the help of a data track?
    Is it possible to add anything to a data track? In my case it would be amazing if I could somehow add the subtitle file (I can try converting to other formats) to a data track.
    Is it even possible to add data tracks to sources and put something on them?
    Best regards,
    Juan
    Glenn Sakatch replied 1 year, 1 month ago 2 Members · 1 Reply
  • Glenn Sakatch
    July 19, 2025 at 2:39 am
    I have only used the data track for closed captioning. You can add a .scc file to the data track, export the show to a few file types…xdcam .mxf is a common one…and you will have embedded captions in your file…but if you bring that file back in, and add it to a timeline, it will retain the data track, but if you start editing with it, the data will break.
    You can’t..AFAIK, match frame a timeline clip to try to maintain the data track attached to that timeline.
    We used to be able to use a hardware symphony box to edit the caption files to a small degree in the timeline, but that was all based around hardware and a tape workflow.
    I don’t think what you are describing can be achieved.
