Activity Forums Adobe After Effects How to add saber to audio spectrum
  • How to add saber to audio spectrum
    Posted by Mohsin Sadiq on November 25, 2017 at 6:50 pm
    Hi, I am trying to make saber follow the path of the lines on audio spectrum however I can’t find a way to do this.
    I want to make saber follow this.
    Any help would be appreciated
    Mohsin Sadiq replied 8 years, 9 months ago 2 Members · 2 Replies
  • Leopoldo Perizzolo
    November 26, 2017 at 5:59 pm
    The fastest way, given your current setup, would be to use the autotracer feature, under the layer menu. You either have to give it a precomp with an alpha trace or at least a contrast trace, then tweak the settings using the preview feature and autotrace for all the comp duration, then wait. Keep in mind that if you change any parameter of your original trace after the autotracing is done, you have to autotrace it again (it is a static feature, that does not change dinamically with changes you make afterwards).
    Hope it was helpful.
    Leo
  • Mohsin Sadiq
    November 26, 2017 at 6:36 pm
    Thanks this worked perfectly
    Mohsin Sadiq
