Activity Forums Apple Final Cut Pro How to add newly imported audio – as a new storyline/angle to existing multi cam Project??
  • How to add newly imported audio – as a new storyline/angle to existing multi cam Project??
    Posted by Babylon Slim on December 18, 2013 at 1:03 am
    I have a 6 camera multi cam Music Video Project I have been working on in depth for 5 days. The “band” has sent me a new & improved .wav file to replace the audio I have been working with on one “song”. I have imported it into the event, cannot figure out how to add it as a new angle (that I will manually sync on the timeline) and then make it the active audio monitor angle. I see ways to “connect it” but not how to have it appear in the 6up display & on its own story/time line in the precision editor. This is like reinventing the wheel. I am losing mu mind. Please help?
    Fascism should more appropriately be called Corporatism because it is a merger of state and corporate power.
    – B. Mussolini
    Babylon Slim replied 12 years, 8 months ago 2 Members · 4 Replies
  • Jeff Kirkland
    December 18, 2013 at 1:40 am
    You can manually add an angle in the Angle editor, sync it up (manually or automatically) and then set that as your new default angle. I think you’ll still need to go back to your project and set the audio angle to the new one though.
    Alternatively, you could just add it as a track connected to your project and turn off the sound in the multi-track clip.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Babylon Slim
    December 18, 2013 at 1:45 am
    Thanks, How do I manually add a new angle? I have tried selecting it, dragging, etc. I am still stumped. Can you explain it as if I was a child?
  • Jeff Kirkland
    December 18, 2013 at 1:49 am
    In the angle editor, you should see a downward pointing triangle next to the angle name. Select that, then choose add new angle (amongst other nifty options that menus gives you).
  • Babylon Slim
    December 18, 2013 at 1:56 am
    Thank you. I need to take a break & eat. i swear knew that & forgot it. Thank you for your quick response… Take Care.
