Activity › Forums › Adobe After Effects › How to add motion trail to a selection?
  • How to add motion trail to a selection?
    Posted by Phire on May 14, 2007 at 7:58 pm
    I want use a motion trail plugin on a man’s hands so that when he moves his hands there will be a motion trail only from his hands. I tried making a mask and tried applying the motion trail to the masked area, but what this does is just apply the motion trail INSIDE the mask and the trail will not go outside of the mask, so it cuts off the trail. What can I do to accomplish this?
    David Bogie replied 19 years, 4 months ago 3 Members · 2 Replies
  • Deleted User
    May 14, 2007 at 9:47 pm
    I would duplicate the layer and rotoscope the hand with a mask. Use the time echo effect on the duplicated layer.
    Lee
    CTV Calgary
  • David Bogie
    May 15, 2007 at 5:49 pm
    ONce you have the hand more or less isolated, you can use several filters. Try CC Time Blend. It requires two copies of the effect, one to copy the area being filtered and one to paste the pixels back into the layer. It is reiterative and difficult to figure out. Does the Copy version of the filter go first or does the Paste version go first? The documentation for the CC effects is not very helpful so you might want to drop by Cycore’s site to see specific examples of theCC Time effects.
    bogiesan
