Activity Forums DVD Authoring How to add commentary stream in a story
  • How to add commentary stream in a story
    Posted by Brandon Donnelly on January 9, 2009 at 5:14 pm
    What would I do if when i want some of the options of the stories to play a different audio track (commentary for example), because when you are going through stories you don’t have the same ability to have the buttons set to a different audio track or subtitle file (like a normal play button would give you when you set its destination under the advanced streams option). Is there a way to add something to the story to resort to the second audio track verse the automatic first track which is the videos audio…
    Thanks very much, Brandon
    Brandon Donnelly replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
