Activity Forums Adobe Premiere Pro How to add another audio track in CS4
  • Andrew Devis
    December 15, 2010 at 4:23 pm
    Hi Edwin
    It\’s probably something to do with the audio track being mono while the sequence is set up as stereo. Pp recognises it isn\’t a default stereo track and puts it on its own track.
    I also did a tutorial about targeting tracks in pp which will show you to make sure your track goes to the right place (as long as it is the correct type – Mon or stereo).
    Hope this helps
    Andrew
    … because it’s all about stories …
