Activity Forums Apple Final Cut Pro Legacy how to add an de-interlace on a master clip after finished editing
  • how to add an de-interlace on a master clip after finished editing
    Posted by Anastasis Lazos on July 28, 2009 at 3:23 pm
    Hi all,
    I ve finished editing a multicam project and now i realize that i need to add de interlace to all clips coming from footage taken by one of the cameras..Instead of going through each clip in my timeline and adding the effect could i add the de interlace on the master clips from that one camera?
    My timeline includes clips from 4 cameras, could i select all clips and add the interlace effect even to those clips that dont need it?
    It ll take me so long to do it one by one, its a 2hour project..!
    Many thanks
    Anastasis
    Anastasis Lazos replied 17 years, 1 month ago 4 Members · 5 Replies
  • Neil Sadwelkar
    July 28, 2009 at 3:41 pm
    Adding it to the masterclip after its in the timeline won’t help.
    If these ‘interlace requiring’ have some common name, extension or character that’s not in the other clips, you could search the timeline for that name, ext or char. FCP highlights each instance of it.
    In the first ‘found clip’ place the filter. Then do cmd-c so fCP copies the clip. Then Cmd-G so FCP finds the next instance and highlights it. Do a paste attributes opt-v and select filters. Then cmd-g again. And opt-v again.
    Hope this helps.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • David Roth weiss
    July 28, 2009 at 4:21 pm
    As Neil says, or you can use the “Find All” command, which highlights every instance of the clip you search, and you can apply the filter to all clips at once.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Michael Sacci
    July 28, 2009 at 4:58 pm
    Since I don’t like what you get by using the deinterlace filter in FCP I would modify the source clip with Compressor.
    First I’m going to assume you are working in a progressive sequence.
    I would take the original file into compressor and deinterlace it there, using Frame Control set to BEST, this is a long process but quality is the best you can get. Export this new clip to the same folder as the source.
    Rename the original clip xxxx(interlace), rename the new clip to be the same as the original clip without the “(interlace)” now when you open the FCP project the new progressive clip will be used.
    The only thing that would could cause a problem is if TC got shifted.
    If for some reason it didn’t work you just remove the “(interlace)” off the original clip, move the new clip and you are back to square one.
    NOTE – anytime I’m trying to force a change like this I also duplicate the project file for a safety net.
  • Anastasis Lazos
    July 28, 2009 at 6:18 pm
    Thanks for the replies guys,
    i ll try the “search” method since those clips have a common word in their naming…Hopefully i could copy the filter to all clips at once with “find all” command..never used search command in fcp but i should be able to figure that out..
    The option of using Compressor to deinterlace the clips kinda scares me a bit in case TC gets altered as Michael warns..
    thanks again
    anastasis
  • Anastasis Lazos
    July 28, 2009 at 6:25 pm
    just did it, took me a min with “find all” command! Useful to know!
    nice, thank you again!
