Activity › Forums › Adobe After Effects › How to add a shine/flare on text
Posted by John Mark on August 29, 2012 at 10:32 pmHow can I add a shine or flare something that sparks across the text just to make it stand out
A News Graphic Lover
John Mark replied 13 years, 11 months ago 3 Members · 4 Replies -
Chris Brett
August 30, 2012 at 8:32 amHi John
There are a number of ways of doing this.
My favourite ‘all purpose’ method for 2D type at the moment is as below.
1 ) add ajustment layer to text layer
2 ) apply cc hue and saturation effect to adj layer
3 ) wind up the ‘lightness’ and ‘saturation’ so that the lettering lo0ks overbright and shiny / metallic ( this will affect all the lettering at the moment )
4 ) add an oval mask to the adj layer so the the shiny section now modifies only an area which is convincing as a light
5 ) Adjust the ‘softness’ of the mask and ‘shape’ of the mask to suit
6 ) go to point on the time-line just before the light hits the type and animate the position of the mask so that it is not applying effect to type ( just to the left say )
7 ) go to point on time-line where the shine is to end and animate mask position so that it is off the type again ( to the far right say )
8 ) ram preview to see result and adjust mask animation to suit required speed / effect
I prefer this method rather than simply adding white to simulate a light as the extra chroma is more convincing I think — just adding white can look a bit flat.
Sometimes I experiment using number of masks — this can give very good and interesting results — say one much bigger and softer to give a general movement and another for the highlight ( say ) / or sometimes e few lights going in different directions etc etc.
Depending on the colour of the type coloured lights can work well also
—- good luck with it all — if you need a bit of info on animating masks etc it worth checking out Andrew Devis’s tutorials on this site ( at least I’m pretty sure he has done this one )
—–chris brett // uk
Stephen Smith
August 31, 2012 at 2:17 pmFor the Shine, motion has pre-built behaviors that will do it just for you.
-Add Text
-Go To the “Library” tab, Behaviors, Text Sequence, Text-Highlighter.
-Apply any of them. I think you would like “Glow Through” the best.
As for a Flare. I feel the flare the comes with FCP, Motion and AE stink. Check out Optical Flares which only works with AE: https://www.videocopilot.net/products/opticalflares/
If you don’t have AE and have Motion 5 check out mFlare: https://www.motionvfx.com/mplugs-1.html
Hope this helps and best of luck.
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Vimeo page
Stephen Smith
August 31, 2012 at 2:25 pmJohn and Chris,
Sorry, I thought I was in the Final Cut Pro forum. For a Flare. I feel the flare the comes with FCP, Motion and AE stink. Check out Optical Flares which only works with AE: https://www.videocopilot.net/products/opticalflares/Here is a great example of what can be done with Optical Flares: https://videohive.net/item/broadcast-design-news-lower-third-package/547899?WT.ac=search_thumb&WT.seg_1=search_thumb&WT.z_author=IronykDesign
Stephen Smith
