Activity Forums VEGAS Pro How to add a scrolling Text Upwards or Downwards
  • How to add a scrolling Text Upwards or Downwards
    Posted by Phani Mahavrathayajula on December 16, 2008 at 11:16 pm
    Hi friends,
    I want to have a scrolling text from bottom to top or vice versa. I know there is “Credit Roll”, but don’t want to use it, because I cannot have transparency with it. What I mean is, I want to have the background transparent so that the rolling titles go over my background video. Also, with the credit roll, I can’t put the key frames. In the credit roll, we don’t see the tabs like “Effects”, “Placement” and the “Properties” tab is limited compared to a normal “Simple Text”.
    I tried to insert a text media and went to “Pan/crop” tried to move the screen up or down, I couldn’t do it. But I can do horizontal left and right hence the text moves left to right or viceversa. But I want to have the text move up / down.
    Any pointers to a tutorial video or steps to do this, highly appreciated.
    Thanks.
    Phani Mahavrathayajula replied 17 years, 8 months ago 2 Members · 2 Replies
  • Rob Strobbe
    December 17, 2008 at 4:37 am
    “I know there is “Credit Roll”, but don’t want to use it, because I cannot have transparency with it”
    Sure you can. In fact, Vegas comes installed with a couple Credit Roll presets with transparent backgrounds. The background color (and transparency) is set on the Styles tab.
    “I tried to insert a text media and went to “Pan/crop” tried to move the screen up or down, I couldn’t do it.”
    On the left side of your Pan / Crop window is a column of buttons. The bottom one toggles the type of movement that is allowed. It sounds like you currently have movement set to Move in X Only. click that button until its tooltip says Move Freely.
    Anyhow, the correct way to do scrolling — if you want to use the standard text generator — is to use the Placement tab. At the beginning of the keyframe timeline, move your text to the bottom of the window. Then set a keyframe at the end of the keyframe timeline, and there move the text to the top of the window.
    Rob
  • Phani Mahavrathayajula
    December 17, 2008 at 5:25 am
    Thanks Rob. My bad eyes. I didn’t see the credit roll on transparent just besides the one on black.
    As you guessed right, on my pan/crop window, Move X Only was selected. Later I changed it to Move both X and Y directions, now I can drag the pan in all directions. Problem solved. Thanks a bunch.
