Activity Forums Adobe After Effects Expressions How to achieve this static trail effect?
  • How to achieve this static trail effect?
    Posted by Thiago Lobo on August 21, 2011 at 4:40 pm
    Ok, everyone…
    So I’m thinking about doing a video and wanted to achieve this effect of painting on the wall, taking a picture, erasing it with white paint and painting another frame (as done by BLU).
    I can’t explain it properly, so here are the references:
    https://www.youtube.com/watch?v=uuGaqLT-gO4 (BLU)
    https://www.vimeo.com/24146622
    Is there some expression or easy way to do so that my layer, while being animated, keeps replicating itself each frame and the replic being static? After that, I could add some colour effect to make it white.
    It’s like using the ECHO effect, but the trail has to be static.
    Any ideas?
    Thanks in advance!
    Thiago Lobo replied 15 years ago 2 Members · 2 Replies
  • Todd Kopriva
    August 21, 2011 at 9:01 pm
    In case it isn’t obvious: This movie was done for real, with actual painting, not with software.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Thiago Lobo
    August 21, 2011 at 10:35 pm
    Thanks for your answer, Todd.
    As you stated, it’s pretty obvious that the movie was done for real. I guessed that, being obvious as it is, it would be equally obvious that I’m trying to achieve a similar effect using a software.
    I suggested 2 videos as reference and if you watch the Vimeo one, you will see that it was probably not done for real, but using a software.
    The point is: the references being done for real or not, I need to achieve this effect using After Effects or some software. I thought about some expressions or using Echo effect as a basis…and I’m asking about some enlightenment on this matter.
    Still waiting for some cool ideas. Thanks!
