Activity Forums Adobe After Effects How to achieve this effect:Trail follow three points of a shape.
  • How to achieve this effect:Trail follow three points of a shape.
    Posted by Kevin Liu on July 22, 2015 at 2:51 pm
    Now what I can achieve is only one trail after each point.like this
    The effect I want to achieve looks like blow.
    There are many trails after each point.
    Trails after each point are different with each other.
    Richard Herd replied 11 years, 1 month ago 3 Members · 2 Replies
  • John Cuevas
    July 22, 2015 at 4:04 pm
    I would use a multiple shape layer and a repeater to create that look.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Herd
    July 22, 2015 at 9:04 pm
    That’s really hard to do. Fortunately, Adobe has a series of pre-made but hard to find Expressions in their expression sampler. I have shared mine from ages ago here: https://drive.google.com/open?id=0B2S2b7kN6I8iX2VLZ1ZESURuUnM
    You want the comp called random rotation. From there, you will have to work through some other details, but the expression, the hard part to write, will work just fine, and you will need to animate the shape layers and probably use a stroke effect and so on.
