Activity › Forums › Adobe After Effects › how to achieve the hula effect ????
  • how to achieve the hula effect ????
    Posted by Aroonzfx on July 18, 2005 at 9:13 pm
    hi all
    i ahve a statue which i mentioned in the previous post
    what is want is the hula effect.. i think the effect is named as such ..
    i will explain anyway
    i want a streak of line with glow to pass from the back of the statue to the front side of the staute .. i think u got what i said
    link : ” target=”_blank”>https://rapidshare.de/files/3162389/streak_glow.jpg.html
    i know how to make the streak of light or glow
    but how can it frm the back to the front ..
    even if i break … the strak layer,,, howo to get teh continuity??
    can i use 3d stroke for the same effect ???
    plz tell me
    aroonz
    Jeff Dobrow replied 21 years, 2 months ago 5 Members · 14 Replies
  • 14 Replies
  • Chris Smith
    July 18, 2005 at 9:43 pm
    Use 3D stroke. Break into it into 2 layers. Use the clipping planes in 3D stroke to make what should be in front on one layer, then what should be in back on the other. Then just put your statue between those layers in the AE layer stack.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Seth Hancock
    July 18, 2005 at 11:05 pm
    Chris,
    I use 3D Stroke a lot but haven’t ever tried to have it encircle a person or object. I would like to and am wanting to try. Therefore, can you can explain what you mean by “Clipping Planes.” I have never heard of this before. Thanks.
    Seth
    wordtoyomutha
  • Chris Smith
    July 18, 2005 at 11:31 pm
    Sure,
    In 3D stroke under the camera section there are Z clipping planes. So imagine you have a person’s head on a layer. Let’s pretend it’s an Earthlink commercial where you want an orbit to loop around their head.
    First do a rough roto of the person’s head. It doesn’t need to be great since it’s just comping back on itself.
    So here are our elements: 1. The original film plate of someone standing talking to someone. 2. The duplicate of this where you masked the persons head so it’s isolated. 3. You’ve created a 3d stroke in a circle and angled the stroke a bit so it looks like an elliptical orbit path.
    Well the prob is that if you put the 3D stroke layer on top of the stack, it doesn’t look like it’s orbiting the head, if it’s between the head layer and the BG layer then you have the same problem but now behind the person.
    So, wouldn’t it be cool if you could split the 3d orbit by it’s depth into 2 layers? So that the near part of the stroke can go on a layer on top of the head layer and the behind part of the stroke can go below the head layer.
    In 3D stroke under the camera section there is Z clip Front and Z clip Back. Duplicate the entire layer that the 3D stroke, circle mask, and solid sit on. But one copy above the head layer and one copy below the head layer. Turn off the below head layer. Now go under the 3D stroke parameters to Z Clip Back and decrease the number quite a bit until you see the back half of the orbit circle disappear. Now remember this number
    Turn off that layer and go to the other layer and set the Z clip front to that number and the front of the circle should disappear.
    Now turn on both layers. Now the circle should look like it’s looped around the head.
    Chris Smith
  • Seth Hancock
    July 19, 2005 at 3:21 pm
    Thanks Chris.
    Dude! You rock! This was perfect and easy. I really appreciate the time you took to explain this. This was very helpful and worked well. Again, thanks.
    Not butt-kissing just simple midwest sincerity.
    Seth
    wordtoyomutha
  • Chris Smith
    July 19, 2005 at 3:49 pm
  • Aroonzfx
    July 19, 2005 at 6:12 pm
    adguy31
    hwo did u get it
    should i use a camera in the composition
    in my case i used the camera, but the half is not revealed as i wish
    this is my still
    ” target=”_blank”>https://rapidshare.de/files/3184742/still_for_hula_effect.jpg.html
    could u help me more on that
    arun_p_g@rediffmail.com
    chris thanx for the detailed explanation
    do u know any tutorials regarding the same ??
    thanx
  • Seth Hancock
    July 19, 2005 at 8:33 pm
    I took Chris’ advice and played around with it. I didn’t use a camera and I didn’t practice on footage. Instead I just used a PSD image of a person I had in my files. I took me a couple of tries but once I got the hang of it I know now how to apply it to video or any other footage. I guess my best advice is to practice a few times but Chris’ explanation is really extensive.
    Seth
    wordtoyomutha
  • Dwaynne
    July 20, 2005 at 2:59 am
    sorry, Chris, but i got the same error aroonzfx got. How do I get this to work? I have trying for a long time and cant figure it out. Your explanation gaveme a glimmer of hope but now…sob! It doesnt work.
    Dwaynne
  • Chris Smith
    July 20, 2005 at 4:12 am
    What error?
    Chris Smith
  • Aroonzfx
    July 20, 2005 at 5:51 pm
    hi chris
    i tried to do as u said..
    instead of the statue, i made a small rectangle (height=720 my comp height
    and width =100)
    i tried your settings…
    the rectangle was placed at the centre
    i made another solid.. made a ellipse mask.. applied 3d stroke
    in the camera rollout.. i adjusted the z clip front
    the default value is 30000.. i adjusted it to make it disappear…. stroke disappears at 355.. at 356 it appears …
    tried the rest as u hav said sir..
    but in vain
    i think Dwaynne Villiers is also having the same probs as he mentioned in his post ..
    how to make it more clear .. sir
    can u help me
    thanx
