Activity › Forums › Adobe After Effects Expressions › How to access pixel RGB values from a script? (not an expression)
  • How to access pixel RGB values from a script? (not an expression)
    Posted by Paulo Jan on April 18, 2014 at 11:17 am
    Hello:
    This is a question about scripting, not strictly about expressions, but I thought it would fit better here than in other forums.
    I am writing a script that needs to access the RGB pixel values of a given comp/layer. Reading through the scripting guide, I haven’t found any way to do it. Is there a way? What I need is to be able to specify a given X/Y coordinates and get back the RGB values of that pixel, as if it was Photoshop.
    Thanks in advance.
    Paulo Jan replied 12 years, 5 months ago 3 Members · 6 Replies
  • Dan Ebberts
    April 18, 2014 at 1:24 pm
    Unfortunately, scripting doesn’t have that functionality directly. You can do it by having the script add a temporary expression though. Add the expression, harvest the result, remove the expression.
    Dan
  • Paulo Jan
    April 18, 2014 at 2:53 pm
    Thanks for your answer. Do you know if it’s even possible to, say, overlay an image over your comp using scripting? For example, add a red overlay to all the parts of the image that have a given value. For an example, see the attached image:
  • Paulo Jan
    April 18, 2014 at 4:55 pm
    More generally speaking, I’d like to know if it’s possible to use either expressions or scripts to manipulate a layer/comp at a bitmap level. That is:
    -Set given pixels to a certain color, based on their brightness level (as in the image above).
    -Take a snapshot of the current comp and perform calculations on it as a bitmap, and then save it as a JPG.
    Thanks in advance.
  • Dan Ebberts
    April 18, 2014 at 5:25 pm
    I don’t know of any practical way to do that with a script. Maybe with a plugin, but that’s a much steeper learning curve.
    Dan
  • Darby Edelen
    April 23, 2014 at 5:16 am
    [Paulo Jan] “-Set given pixels to a certain color, based on their brightness level (as in the image above).”
    You could use one of the keyers (Color Range? Extract?) and Channel > Solid Composite to do that.
    [Paulo Jan] “-Take a snapshot of the current comp and perform calculations on it as a bitmap, and then save it as a JPG.”
    This part has me a little confused. If you want to perform calculations on the image inside of AE then I would expect that is most likely scriptable depending on what the goal is. What is the goal?
    Darby Edelen
  • Paulo Jan
    April 23, 2014 at 3:13 pm
    Okay, let me explain. I’m trying to port to After Effects this Bridge script:
    https://davidmilligan.github.io/BridgeRamp/
    Which deflickers an image sequence. The way it works is by computing an histogram of every selected image, then comparing the brightness level of a given percentile and adjusting the images’ exposures until they all match.
    For it to work, I need to access AE’s composition as a bitmap, measuring the pixel’s RGB values to construct the histogram. That can be done using Dan’s method, though it’s a bit kludgy…
    …but the script also provides a preview of which parts of the image are in a given percentile. You select a value, hit “Preview” and it shows you in red the corresponding parts of the image. The way the script does it is by creating a temp JPG file, which is why I was asking about that in my previous question.
    Now that you mention using one of the keyers… I’ll have to think about it. But still, it’s quite a kludge (reading the AE scripting guide, it’s obvious that it’s not designed to do stuff like this *at all*), and there’s also the matter of performance…
