Activity Forums Maxon Cinema 4D How to…
  • How to…
    Posted by Blahtor Magnus on December 7, 2009 at 10:37 pm
    Hi, I am new to Cinema 4D.
    I created a small animation and i want to render it to video.
    I seem not to be able to do so.
    Tweaked the Output settings and told the program to export the rendered result as AVI, then as QuickTime movie, I also made sure to set it to “All frames”… nothing worked.
    Is there any secret to rendering video in Cinema 4D that i am missing here?
    Blahtor Magnus replied 16 years, 9 months ago 2 Members · 2 Replies
  • Brian Dugan
    December 8, 2009 at 5:03 am
    Hi. Check the OUTPUT section in the Render Settings window.
    Be sure you have the frames you want To-From correct.
    Then a quick click on the RENDER IN PICTURE VIEWER button (middle clapboard looking icon thing) and it should start.
    Brian
  • Blahtor Magnus
    December 8, 2009 at 2:52 pm
    Thanks.
    I was using “Render all frames” setting in the Output options.
    Funny that it didn’t render anything but the first frame only.
    Now I am manually setting the frame range, as you advised me, and it is working.
    Hmmm…
