Activity Forums Adobe After Effects How they do this effect and what this technique is called?
  • How they do this effect and what this technique is called?
    Posted by Jihad Akoury on June 15, 2015 at 12:43 pm
    Hello all,
    Yesterday I was watching a video about the visual effects in the TV series game of thrones
    Here’s the link
    https://www.youtube.com/watch?v=vlaAlH1LVgw&index=13&list=WL
    I noticed that they often use a technique called CG to add details to the scene. For example they extend a wall, add some rocks, trees, mountains…
    But what is remarkable that when they add those elements, they don’t show that they used green screen (as they’d done in some other places in the video). And since no green screen is used how could actors walk “In front of those elements”. I added two captures so you will understand what I mean.
    The first one is the scene before editing, and the second one is after adding some elements and we see that the actor’s head is over the rock in the background.
    How could this be done without green screen?
    Or they had used green screen and didn’t show it?
    Or there’s a special technique?
    And if there’s a technique, can it be done on after effects?
    If no which software is used to do such effects?
    And finally what is the best and easiest software for cg modeling?
    Another thing troubles me. How do they create such realistic water??? I tried to learn 3ds max but it is too hard. Now I’m learning cinema 4d, simpler but not as effective. So what software is used?
    Sorry for asking much questions, audio/visual is my ambition and i’m really curious about it.
    Thanks for your answers in advance
    Heath Alseike replied 11 years, 2 months ago 3 Members · 2 Replies
  • Stephen Smith
    June 25, 2015 at 5:35 pm
    The link doesn’t seem to work so I can’t watch the video. They could have keyed it and just skipped that part of the video. But if something is shot with out a green screen and they need to cut part of a person out it is called rotoscoping. I did a video where the green screen wasn’t big enough so I had to do a lot of rotoscoping. Take a look at the spot here:
    https://vimeo.com/76003006
    Then watch the side by side:
    https://vimeo.com/76622200
    To learn more about this I would check out some of the tutorials on Video Copilot like this one:
    https://www.videocopilot.net/tutorials/alien_surface/
    Hope this helps and best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Heath Alseike
    July 16, 2015 at 5:35 pm
    I am not sure how much you know about post-production. Starting with the basics, I think you are talking about a technique called compositing. Rotoscoping is one way to composite footage. There are many techniques used to layer elements into footage. I would suggest youtubing and learning all about compositing. That should explain how they added all the extras to any scene.
