Activity Forums Avid Media Composer How They Do That? Layered Video
  • How They Do That? Layered Video
    Posted by Qb Film on October 18, 2006 at 8:09 pm
    Hello to all, everything has been fine so far, so I haven’t had the reason to post on the site in a while, but I’m curious as to how music videos/films use layered video. I understand that if they leave the camera in the same location, same angle, and don’t have the character cross the center of the frame, then they should be able to layer the video properly. But as far as editing, how do they layer it for editing purposes? Is is After Effects, Avid? Or something different?
    I know in Avid, their is the Superimpose, but the video won’t be the same opacity. Any ideas? I have the Avid Express Pro HD on PC. Just curious
    Melivn Royster
    Express Pro HD 1.5
    Windows XP
    1.00 Gig RAM
    AMD Motherboard
    Melvin Royster
    Producer/Director/Editor
    http://www.qbfilms.com
    Qb Film replied 19 years, 11 months ago 5 Members · 5 Replies
  • Milton Hockman
    October 18, 2006 at 10:05 pm
    all you do is lay clip 1 (without person in it) on the timeline.
    then put clip two next in the timeline (with someone in it)
    you can slip the edit so that your in point on the second clip contains the person already in scene.
    or
    you can use a cross dissolve from clip 1 to 2. this will mamke the person slowly appear in the shot.
    it is very easy to do.
    noone will know that you actually cut to the next shot because the backgrounds are completeley the same.
  • Michael Hancock
    October 18, 2006 at 10:34 pm
    If you want one person standing next to themselves, shoot it so they don’t take up the same space in the room (say one person stage right, then other stage left) and lock off the camera. Shoot the person doing their bit stage right, then shoot them again stage left. Cut your two shots onto V1 and V2, apply a PIP to V2, crop it off so doesn’t cover the person on V1 and voila! You now have one person, on screen, standing next to themselves. If you want them to walk around or cross you’ll have to either rotoscope one of them out or shoot the scene empty (background plate) and try to pull a difference matte. Search these forums and the After Effects forums for some good info on rotoscoping and matting techniques.
    Mike.
  • Oakmozart
    October 19, 2006 at 3:22 am
    A simple mask will allow you to do this too. Stack your 2 video layers on top of each other, then apply a mask to separate the 2 layers, hiding half of each one. In Media Composer, you can do this with Animatte. In XPro, you’ll need Avid FX, Boris Red, Boris FX, or you’ll have to enlist the help of After Effects, Combustion, etc.
  • Jon Zanone
    October 19, 2006 at 11:34 am
    …Or you could use a wipe on layer two. Use the wipe as a segment effect instead of a transition. Wipes are our friends. Just ask George Lucas…
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Qb Film
    October 20, 2006 at 4:47 am
    Good ideas, I’ma give it a try and play around with it. thanks.
    Melvin
