Activity › Forums › Adobe After Effects › How stable is CS5 Mac?
Posted by Doug Nash on July 4, 2010 at 6:55 pmI searched a little, and found that there is at least one known issue with CS5, which is the AIFF RAM playback bug. If simply converting to WAV resolves that, I can totally live with that.
But what about the rest of the program? I currently use CS3 on a 8-core Intel Mac, running 10.5.8. It’s incredible stable. But, I’ve heard some very poor assessments (from credible colleagues) about the performance and overall reliability of CS4.
I have NO interest in upgrading, for the increased speed and robustness of 64-bit in CS5, if it comes with instability, or other speed issues.
What say those of your with empirical experience in what I just detailed?
Todd Kopriva replied 16 years ago 4 Members · 11 Replies -
Doug Nash
July 4, 2010 at 7:45 pmThanks, and I couldn’t agree more about waiting for a spell, before upgrading hardware & software.
However, I’m cranking through a bunch of work right now, and AE is becoming a bit of a bottleneck. Apple isn’t helping, by turning its back on us professionals with a lack of Pro updates, so in the meanwhile, I’m updating certain key apps.
I’d have to imagine that there are some significant render speed boosts, going from CS3 to CS5.
So, unfortunately, my happiness has to be based on some quantifiable results. Who is using CS5 in the workflow, right now, and can you please advise on speed gains over CS4 & CS3?
Thanks.
Uli Plank
July 5, 2010 at 7:47 amDon’t expect massive speed gains, this is not Premiere Pro. You may get some 30% on average if you have plenty of RAM (minimum 2 GB per core). Stability got much better when working with large images, though (we use 4K).
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Dean Sensui
July 5, 2010 at 11:10 amI did some work with it and it allows you to use all the RAM in your Mac, as opposed to the 4-gig limit.
However, Primatte and other Red Giant plug-ins that I use aren’t available for CS5 yet. Due this summer. You might want to see if your plugins are compatible before making the jump.
For any upgrade, I make a complete working copy of my HDD before installing any changes. If it doesn’t prove totally functional I can always jump back to the previous setup.
Dean Sensui — Hawaii Goes Fishing
Doug Nash
July 5, 2010 at 9:21 pmThanks for the continued input. I’ve already done the due-diligence on my mandatory plugs, and they’re all 64-bit compliant.
I’m not especially worried about redundancy, as CS5 will be a fresh install. CS3 will work just fine, if I have to fall back for any reason. Out of curiosity, why do make such a thorough copy before installing an app?
Cheers.
Doug Nash
July 5, 2010 at 9:23 pmUli. Thirty-percent is a huge margin, when applied to day-long renders. Are you just throwing that out, very much off the cuff? Or have you calculated that by comparing identical projects, between the older version of AE?
Thanks.
Dean Sensui
July 5, 2010 at 9:49 pm[doug nash] “why do make such a thorough copy before installing an app?”
One never knows what might trip up things. It’s just a precaution. Like wearing seatbelts or having a fire extinguisher in the house.
Doug Nash
July 5, 2010 at 9:58 pmCan’t argue with that. Out of further curiosity, how do you go about making your back-up system drive? Do you use Time Machine, and an external drive? Is it a perfect duplicate, in that you could simply swap that drive for the system, and boot right up without a hitch?
Thanks.
Dean Sensui
July 5, 2010 at 10:21 pmI use “Super Duper” and make a duplicate on an internal HDD that’s inside the MacPro itself.
Then it’s just a matter of assigning it as the “boot drive”. Pretty easy to flip-flop from one to the other.
Doug Nash
July 5, 2010 at 11:34 pmSweet. I think I’ll give that a go, myself. I’ve got a number of separate computers for redundancy, but with the absurdly low cost for HD’s, that would be a smart move.
Uli Plank
July 6, 2010 at 2:14 pmIt’s an average. There are huge differences depending on the filters and functions you use, it can range from a tad slower all the way to nearly 50% faster. You’ll need to fine-tune the use of your cores and RAM too, Todd Kopriva is giving some very good info about that. So, it’s hard to give a straight number – too many variables.
