Activity Forums Adobe After Effects How should I export files from AE so I can use them in Premiere without loosing quality?
  • How should I export files from AE so I can use them in Premiere without loosing quality?
    Posted by Igor Vukojevic on May 13, 2014 at 5:13 pm
    My editor exports everything as Pro Res, but he works with a Mac and I have a PC.
    How should I export files from AfterEffects or Premiere so that I can use them in another program without loosing quality?
    Thank you.
    Todd Kopriva replied 12 years, 4 months ago 3 Members · 3 Replies
  • Kevin Camp
    May 13, 2014 at 5:54 pm
    Quicktime Photo-JPEG is very good. at high quality settings (90-99) any loss is practically imperceivable at that level of quality the files will be larger that prores, but higher quality. i couldn’t tell you exactly what quality setting would equate to prores 422, but you might be able to find that info on the web. it’s a standard part of quicktime, so you already have it on your system.
    avid also has a free codec (available from their site) called dnxhd, which is practically identical to prores, and it will work just fine with ae and premiere.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Igor Vukojevic
    May 13, 2014 at 6:27 pm
    Thank you so much.
  • Todd Kopriva
    May 13, 2014 at 7:59 pm
    If you want a losslessly encoded file with an alpha channel, a QuickTime movie using the PNG codec is a good choice.
    We include DNxHD in After Effects CC (12.0) and Premiere Pro CC (7.0) and later.
    After Effects team blog
