Activity › Forums › Apple Final Cut Pro Legacy › How should I be Upressing 1280×720 Pro Res (no fields) to Uncompressed 1920×1080 (upper fields)?
  • Lu Nelson
    June 6, 2008 at 7:46 am
    Hi Rafael,
    I did some unscientific tests with Instant HD when it first came out and my results had little artifacts throughout, like pixels or groups of pixels that would sort of crawl, wiggle around and sometimes just sort of flip out like the signal was breaking down there. I found the upres results with Compressor (since version 2) to be much better, as long as you use its highest quality settings for scaling.
    However, I was testing with relatively low quality SD footage, uprezzing to HD so that really pushes the capabilities of the software. You can of course download the Instant HD demo and try it yourself, it may be better if your 720p footage is already pretty sharp, etc.
    You can also try Digital Anarchy Resizer, but I believe this will also not be appreciably better than what you’ve got with Compressor. The retiming/resizing algorithms Apple built in there since v2 are really very good
    Best of luck
    LMN
    Lu Nelson
    Berlin, Germany
  • Rafael Amador
    June 6, 2008 at 9:17 am
    Hi Lu,
    Thanks a lot for your helpful info.
    Rafael
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
Page 2 of 2
