Activity Forums DaVinci Resolve How set keyframe in Color
  • How set keyframe in Color
    Posted by Bob Cole on January 23, 2022 at 2:21 pm
    How do you set a keyframe in Color? I’m trying to KF a mask to eliminate bad parts of a chroma key BG, in order to keep the keying as mild as possible. I see that I need to switch from Clip to Frame but I don’t see how to do that.
    Bob C
    Resolve 17.latest, OSX latest
    Bob Cole replied 4 years, 7 months ago 2 Members · 2 Replies
  • Michael Gissing
    January 24, 2022 at 3:08 am
    It’s in the tracking window on the Color page. Resolve does and excellent job tracking a mask so you might not need to keyframe but if you want to adjust a tracked mask, change the tracker from clip to frame and just make adjustments on the frame you want. It automatically places a keyframe when you adjust in frame mode.
    You can also set and delete keyframes manually. The tools are at the bottom of the tracking graph.
  • Bob Cole
    January 27, 2022 at 4:07 pm
    Thank you Michael. Your tip motivated me to dig into the Tracking window, which I’d been avoiding because I assumed it would be as cumbersome as other tracking tools I’ve used… and I’m glad to report that I was wrong; it is excellent.
    In the “Window” window, just to the left of the Tracking window, the only way I’ve found to add a keyframe is to set a mask and then adjust it manually. Still willing to be corrected about that.
    Thanks again.
    Bob C
