Activity › Forums › Apple Final Cut Pro Legacy › How not to capture extra DVCPro HD frames?
Posted by Fred Grossberg on February 4, 2006 at 11:00 pmI
Fred Grossberg replied 20 years, 7 months ago 2 Members · 3 Replies -
Fred Grossberg
February 7, 2006 at 8:42 pmI’ve made some progress on this issue. The DVCPro selects tape I’m having the problem with has drop-frame (DF) timecode. I’ve tried capturing from other tapes with nondrop-frame (NDF) tc, and no extra frames are added. So I assume this the culprit. I’ve discovered that Apple tells you not to use DF with DVCPro HD. I wish I’d known that earlier. Anyway, someone suggested I try capturing through RS-422 as opposed to FireWire. I’ve ordered an adapter and will try that in the next day or so.
Walter Biscardi
February 7, 2006 at 8:54 pm[Fred Grossberg] “The DVCPro selects tape I’m having the problem with has drop-frame (DF) timecode.”
720/60 on DVCPro HD is NDF by nature. The only DF timecode I’ve seen on DVCPro HD is true 30p. Not sure how the 720/60 go DF timecode.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Fred Grossberg
February 7, 2006 at 9:02 pmWalter: Thanks for replying. I’ve read your threads on DF and NDF timecode and admire them greatly. These DVCPro HD tapes are HDSDI dubs from D5 masters that inadvertently were striped DF.
–Fred
