Activity › Forums › Apple Final Cut Pro Legacy › How much space must I leave open on an external HD?
Posted by Noam Osband on June 7, 2011 at 5:50 pmI know the rule of thumb one should leave 10% of the space open on a internal HD. Is the same true for an external HD? I’m editing with a 2TB that only has 50 GB open. Is that a problem?
André Engelhardt replied 15 years, 3 months ago 3 Members · 4 Replies -
David Roth weiss
June 7, 2011 at 5:54 pmYou’re definitely pushing the envelope and most likely getting a mere fraction of the normal throughput of that drive, which means that your realtime performance is being limited and you’re having to render much more than than you should be.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
David Roth weiss
June 7, 2011 at 5:59 pmThere’s no precise number Noam. 200Gb will work. Just keep in mind that you only hurt yourself when you overload drives. With the price of hard drives today there’s simply no reason to skimp.
David Roth Weiss
Los Angeles
André Engelhardt
June 7, 2011 at 6:50 pmHi Noam,
one thing that comes into play when considering how much space should be left free is depending on how big the data chunks you dump onto the drive will be.
If you have only a lot of smaller file chunks on the HD (say up to 100MB-300MB) and you still have several GB free then the chances that a file of the same size will become fragmented is small, however if you have lots of big files on the HD and you throw on more big files then there’s a very good chance they will be fragmented slowing down read/write operations.
Hope that makes sense!
André
Sound, Music, Film, Photo
http://www.andreengelhardt.net
