Activity › Forums › Apple Final Cut Pro Legacy › How much RAM is too much RAM?
Posted by Mark Gringo on November 3, 2005 at 1:39 pmour production house is getting its first g5 dual processor. we will be editing alot of HDV projects. is 2 gigs of RAM sufficient? are we throwing our money away after certain amount of RAM. I’ve heard that you can actually have too much RAM. Is there a “sweet spot” in terms of memory? tying to find the most bang for our buck. thanks cow!
Richard Martz replied 20 years, 10 months ago 7 Members · 17 Replies -
Jerry Hofmann
November 3, 2005 at 1:57 pmMama always said you cannot have too much RAM. That said, it all depends on how many apps you intend to run at the same time. Motion LOVES RAM so does Photoshop, After Effects… etc…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Mark Gringo
November 3, 2005 at 2:00 pmmore sweet RAM… auhhhggghhh
i think we’ll start with 2 gigs. maybe later we can shoot it up to 4.
Jerry Hofmann
November 3, 2005 at 2:04 pmExcellent idea… see if you need more. I’m running with 2.5 gigs, and feel the need for more, but also running a lot of apps at the same time. You can always add more as you need it too.
Jerry
Mark Gringo
November 3, 2005 at 2:28 pmis there anything to becareful about when adding memory? someone was telling me that you have to add it pairs? this is a pc person saying this. the g5 dual has 8 slots, right? can i mix and match 512, 1 gig, and 2 gig memory sticks? or am i restricted in some way, like adding memory in pairs?
Richard Martz
November 3, 2005 at 2:31 pmI am doing the same kind of workflow and I’m currently using 4 GB of RAM. I would prefer to have 8 GB. So I recommend having as much as you can afford. You just want to avoid having your applications slow down. SO the more memory the better. I’ve never heard of having too much memory. I found a cheaper source for memory so I’ve actually loaded up at a cheaper price.
Apple charges $1500 for 4GB 533 DDR2 ECC SDRAM- 4x1GB –
OR
$700 for 4GB 533 DDR2 Non ECC SDRAM- 4x1GBYou can get the same chips at MAXUPGRADES.com for around $500. I’ve been runing this memory chip set for 2 months with no problems so I recommend it.
They sell a 1 GB memory module for $119 so I bought 4 of them. They work great at around 40% off the price from APPLE.
I hope that helps.
BTW – I also installed their SATA drive array in my CPU bay. I purchased one extra 400 GB SATA from Apple and added 3 of 300 GB drives from maxupgrades.com. I striped these as a RAID 0 (zero). THat gave me 1.3 TB of disc memory and more than enough throughput to do DVCPROHD or HDCAM when I need to do a project in a higher quality HD medium. These drives have amazing throughput and I’m really impressed. The cost of the drives, PCX SATA card and mounting hardware was under $700. Also got all the advice I coudl stand and several follow-up calls to be sure I was happy and working well. AMAZING!
Gary Adcock
November 3, 2005 at 2:34 pm[Jerry Hofmann] ” see if you need more.”
IMHO 2 gigs for any HD work is a bare minimum,
remember that you need 1 gig of RAM just to be able to launch FCP for HD work.
In my experience 4 gigs is the sweet spot.Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Richard Martz
November 3, 2005 at 2:35 pmYou WILL have to add memory sticks in pairs. However you can mix the cards. For example, you can have 2, 1 GB cards and 2, 256 cards and 2, 512 cards and they will work fine. See my other post for information on getting memory cheaper than the price from Apple.
Mark Gringo
November 3, 2005 at 2:39 pmi found 1 gig memory sticks on dealram.com for $89.00. they are generic though… i’ve used generic ram before and haven’t had a problem. what do you thinkg about putting 4, 1 gig sticks in a g5?
Richard Martz
November 3, 2005 at 2:42 pmThat is exactly what I did and it is working perfectly. So I can’t recommend your chip supplier but I can endorse it in principle.
