Activity Forums Boris FX How memory intensive is RED 3 particle system?
  • How memory intensive is RED 3 particle system?
    Posted by Steve Pankow on June 10, 2008 at 4:20 pm
    I have a 10 second comp with a single emitter generating a custom shaped particle stream (spine primitive star). I’m watching the Windows Task Manager PF Usage graph rocket upwards throughout the whole render. If I push the comp length any further I’ll run out of memory (2GB) and crash.
    Is this typical behavior? Even when creating the comp and using the spacebar to stop/start and make adjustments, the PF usage always goes up and never down until I’m out of memory.
    Peter Mcauley replied 18 years, 2 months ago 2 Members · 2 Replies
  • Peter Mcauley
    June 10, 2008 at 5:39 pm
    Hi Steve,
    If you could please send me the comp that illustrates this issue then I can take a look at it to see if it’s happening here.
    You can send that to me at peterm@borisfx.com
    Peter.
  • Peter Mcauley
    June 10, 2008 at 7:52 pm
    Hi Steve,
    Thanks for passing along that file – I used it to reproduce the issue that you describe, which is that rendering this file to anything longer than a 10 second clip is not possible, as the application becomes unstable. We’re investigating the issue right now.
    Peter.
