Activity › Forums › Apple Final Cut Pro Legacy › How many hours have i worked on this?
Posted by Ala Taha on October 13, 2009 at 1:54 amDoes anyone know if there is a way to see how long i have worked on a final cut project? I know it’s a long shot but it would be nice if there is. Thanks in advance.
Anthony Dalesandro replied 16 years, 11 months ago 6 Members · 6 Replies -
Rebecca Gillaspie
October 13, 2009 at 4:16 amGo to your autosave vault.
“Imagination is more important than knowledge.” Albert Einstein
Rebecca Gillaspie
Producer, Editor
rgillaspie@gmail.com -
Ben Holmes
October 13, 2009 at 3:46 pmThe autosave vault is usually set up to keep a maximum number of saves, so it will likely have deleted the older saves. Nice idea though – I’m guessing the OP has been working on this for a while…
As far as I know, it’s the only possible way of checking this – perhaps if you use Time Machine to back up project files?
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producerhttps://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Ala Taha
October 13, 2009 at 5:48 pmActually it hasn’t been that long so i think all the saves are there. The autosave vault didn’t give me the exact number but it helps give me an idea. Thanks to both of you.
Christopher Griffin
October 13, 2009 at 7:12 pmI usually keep a pad of paper on my desk and annotate my hours worked. Little notes like “930-1100 – Capture”. Doing so helped me realize I was editing rather quickly but I got sidetracked a lot. After removing my distractions, I cut my work time nearly in half. May not help those who get paid hourly, but definitely helps you if its $/project.
Mark Suszko
October 13, 2009 at 8:04 pmYou might use the built-in sticky notes app to sign in and sign out every day.
“Oh, you wanted to RECORD that?”
Anthony Dalesandro
October 14, 2009 at 11:25 pmI use Google calendar to track my hours for each project. That way I can access my hours from home to do the invoicing.
Anthony Dalesandro
anthony@anthonydalesandro.com
https://www.anthonydalesandro.com
