Activity › Forums › Adobe Premiere Pro › How long of a Premiere Sequence is TOO LONG?
  • How long of a Premiere Sequence is TOO LONG?
    Posted by Patrick Kilchermann on November 13, 2013 at 3:19 pm
    Hello friends,
    I have about 4.75 hours of content to edit, which will be put on three DVDs.
    My problem is, I’m not sure yet where the footage will be split yet for the DVDs (we won’t know until we see the timestamps on each section, because each will need its own intro / conclusion filmed, and those will depend on what fits on each disc, etc).
    Anyway, is it okay for me to end up with this 4.75 hours all on one sequence? It’s a two-cam set, so it’s about 400GB worth of footage, multi-media, etc.
    I’m assuming I’ll just be able to copy-and-paste the other two thirds into their own sequences when I’m finished with the whole thing.
    Does anyone see a reason why I shouldn’t do this?
    Thank you!
    Pat
    Tero Ahlfors replied 12 years, 10 months ago 3 Members · 4 Replies
  • Peter Garaway
    November 13, 2013 at 5:36 pm
    You can have to up to a 24 hour sequence in Premiere. 4.75 hours should be ok. I’ve seen some bottle necks with 8+ hours sequences that contain lots of cuts, effects and layers. The problem is the project file can get quite large. But from what you have laid out you should be fine.
    I haven’t done a lot of work with long reels so others with more experience may want to chime in.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Tero Ahlfors
    November 13, 2013 at 6:44 pm
    I did a movie online that had over 3 TB of footage in CS6. The project usually loaded up for a while but after that it was pretty smooth.
  • Patrick Kilchermann
    November 13, 2013 at 6:46 pm
    #&@^$!!! That is incredible! Was it a 4k movie? is there any clips of it anywhere? I need some editing inspiration this morning… I’ve got the “just crossed the 50% mark” blues.
  • Tero Ahlfors
    November 14, 2013 at 5:07 am
    It was only full HD but there was a lot of different kind of footage. Here’s a trailer: https://www.youtube.com/watch?v=XVwkQrn-8JA
