Activity Forums Apple Final Cut Pro Legacy How long can a sequence be?
  • How long can a sequence be?
    Posted by Melissa on March 17, 2014 at 10:21 pm
    We are using FCP 7 on various machines. In general, when working with Apple ProRes media, how long can a sequence be before causing problems?
    Thanks as usual for all your help!
    Melissa
    Shane Ross replied 12 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    March 17, 2014 at 10:40 pm
    I’ve had a 5 hour sequence before…that’s the longest I got. It was a combination of the same show, but 4 different versions of it.
    Shane
    Little Frog Post
  • Melissa
    March 17, 2014 at 10:48 pm
    Just to be clear, I don’t mean how long FCP will actually let a sequence be. Is 5 hours the limit for having a sequence that playback and edits with out causing a fuss to the system?
  • Shane Ross
    March 17, 2014 at 11:14 pm
    Depends…what computer are you using? How much RAM? What OS? What sort of drive is the media stored on? Connected how?
    Things will get slower the longer the sequence…but mainly in the time it takes to load it. Project Size is a factor in slow down.
    Shane
    Little Frog Post
  • Melissa
    March 17, 2014 at 11:33 pm
    We are working from 2 or 3 machines. The lesser of the bunch is a MacBook Pro with 8GB of RAM with OS 10.7.5
    Our media is stored on a few external hardrives, mostly G-Tech drives that are connected with firewire 800. Some are daisy-chained, others are plugged directly into the machine. (Actually, that would be the case for our more powerful tower. In the case of the macbook, all but one are daisy-chained.)
    Thanks.
  • Shane Ross
    March 17, 2014 at 11:40 pm
    Things might get slowish if using FW800 drives. That’s the lowest end connection recommended for ProRes. WHEN will it get slowish? Not sure. I did that 5 hour timeline on my 2008 MacBook Pro. My newer one is better.
    Shane
    Little Frog Post
  • Melissa
    March 17, 2014 at 11:56 pm
    What connection would you recommend for ProRes? (In an ideal world..)
  • Shane Ross
    March 18, 2014 at 12:07 am
    FW800 is fine…but ideally eSATA or Thunderbolt.
    Shane
    Little Frog Post
