Activity › Forums › Zaxwerks › How large can I make a layer map (pixel dimensions) for ProAnimator?
  • How large can I make a layer map (pixel dimensions) for ProAnimator?
    Posted by James Huenergardt on April 24, 2012 at 2:16 pm
    I’m trying to create an animation using ProAnimator where I have a globe and the continent of Africa is filled with video tiles (using a trkmat).
    I’m wanting to start with the camera pushed into a single tile and then pull out to reveal the continent of Africa on the globe.
    I can get this to work, but I’m currently not happy with the results.
    I’m wanting to have hundreds of clips filling Africa, but right now, the most I can get is about 67.
    The issue is that when I push the camera in close enough to fill the frame with one video tile, the tile is soft.
    I tried making a bigger layer map, but then ProAnimator doesn’t seem to show anything.
    Any ideas/suggestions? What’s the max pixel dimension of a layer map for ProAnimator?
    Jim
    Reel Inspirations – http://www.reelinspirations.com
    Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
    Edward Wu replied 14 years, 5 months ago 2 Members · 1 Reply
  • Edward Wu
    April 25, 2012 at 12:29 am
    Hi Jim,
    As discussed on the phone, try rendering out the Pre-comp since you’re using such as large Layer Map. Then use the video as a Layer Map and see if this works better for you.
    If you’re still having problems, please let me know. You can contact me directly at ed@zaxwerks.com and I’ll be able to help you out.
    Best,
    Edward
