Activity Forums Apple Final Cut Pro Legacy How is this workflow?
  • How is this workflow?
    Posted by James Bishop on December 14, 2010 at 4:41 pm
    Hey,
    I’ve recently started doing wedding videos and was just wondering if anyone could give me some advice as to whether the following workflow is OK…
    A-Cam is a Z1, shooting 50i, capturing into FCP as ProRes422
    B-Cam is a DSLR (T2i), shooting in 30fps, converting to ProRes422 in compressor, before bringing into FCP.
    I then apply a deinterlace filter to all Z1 footage.
    I export as Quicktime Movie, and convert to DVD Best Quality 90mins in Compressor, before importing in to Studio Pro.
    Thanks! James
    James Bishop replied 15 years, 9 months ago 4 Members · 6 Replies
  • Rob Grauert
    December 14, 2010 at 5:10 pm
    Is there a reason why you are shooting two different frame rates – 30fps (btw, is it progressive or interlaced) and 50i? Make it easy on yourself and shoot the same frame rate and resolution with both cameras.
    If you were referring to the De-interlace filter in FCP, NEVER use that. It just tosses out one of the fields.
    Your FCP > Compressor > DVDSP idea is correct though.
    But like I said, shoot the same frame rate and resolution on both cameras.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • James Bishop
    December 14, 2010 at 9:23 pm
    Cheers for the advice Rob. Unfortunately I don’t think a Z1 & a t2i can shoot in the same frame rate? Am I wrong about that? The t2i shoots progressive… The Z1 is interlaced
    James 🙂
  • Shane Ross
    December 15, 2010 at 1:20 am
    [James Bishop] “Unfortunately I don’t think a Z1 & a t2i can shoot in the same frame rate?”
    They can…29.97fps. OH, but you have the PAL version of the camera. Didn’t get the PAL version of the T2i? So you are mixing STANDARDS….NTSC and PAL
    [James Bishop] “Am I wrong about that? “
    Yes. Both the T2i and the Z1, in NTSC land…shoot 29.97fps. the 550D…the European version of the T2i…should should 25p. Does it not?
    [James Bishop] “The t2i shoots progressive… The Z1 is interlaced”
    That has zero bearing on frame rate. It’s the difference between full frames, and video with two interlaced fields per frame. Both can run at the same FPS
    Shane
  • James Bishop
    December 15, 2010 at 11:49 am
    Thanks Shane. As you can tell I am a little clueless when it comes the technical side of things.
    My t2i was bought from Hong Kong and i dont know if it is PAL or NTSC, but it doesn’t shoot 25fps. It shoots 24fps, 60fps & 30fps.
    My Z1e (which is secondhand and was originally bought new in the US), only shoots 50i & 60i.
    What do you think would be the best set-up for both cameras? Is my current workflow the best I can do?
    James
  • Neil Sadwelkar
    December 15, 2010 at 12:54 pm
    From the Canon UK site, the Canon 550D which is what its called in EU/UK can shoot
    1920 x 1080 (29.97, 25, 23.976 fps)
    1280 x 720 (59.94, 50 fps)
    640 x 480 (59.94, 50 fps)
    Link
    https://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_SLR/EOS_550D/index.aspx?specs=1&source=selector
    And from the DP review site, the Canon T2i which is what its called in the US can shoot
    1080p @ 30, 25 or 24 fps
    Link
    https://www.dpreview.com/previews/canoneos550d/
    Even the Canon Hongkong site says the T2i can shoot
    Full HD: 1920 x 1080; 30p/25p/24p
    Link
    https://www.canon.com.hk/en/product/catalog/productItemDetails.do?categoryID=6&seriesID=15&prrfnbr=100365
    So how come your camera can’t shoot 25?
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • James Bishop
    December 15, 2010 at 5:15 pm
    I’ve just realised that I have been a bit of an idiot and did not realise that I had to switch the camera from NTSC to PAL in order for the 25fps setting to appear.
    So would I be best off shooting the T2i in 25fps with the Z1 in 50i?
    Or would I better off shooting the T2i in 50fps (1280×720) and the Z1 in standard definition (DVCAM) at 50i? Would this be a better option for videos that I don’t need to be full HD?
    Cheers
    James
