Activity Forums Adobe After Effects How is this FX title called?
  • How is this FX title called?
    Posted by Susan Lan on March 19, 2017 at 2:03 pm
    The intro of this video is the title “SONDUCKFILM” movement letter each one, I want to find a tutorial in order to do that, so, how is this FX called, please? anyone knows how can I achieve it or how to find a tutorial about in please? Thank you
    From minute 00 to 0:05
    https://www.youtube.com/watch?v=mtOizNUJtNk
    Kevin Camp replied 9 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 20, 2017 at 6:34 pm
    if you are looking to create your own using text animators, try this:
    twirl down the text layer properties, click the ‘animate’ menu to the right of the ‘text’ property group and select ‘enable per character 3d’.
    from the same menu, select position to create an animator for that property. then, from the ‘add’ menu to the right of that animator select property>rotation to add that property to the same animator.
    also from the same ‘add’ menu choose selector>wiggly to add a wiggly selector, and you can delete the default range selector from the animator.
    for a basic setup, try setting the z rotation for the animator to be 90 and the position to be 50, 50, -2000. you’ll likely want to modify those later, but those should get you started.
    if you scrub thru the timeline now, your letters will be randomly moving around.. not quite what you want. to stop that random movement, in the wiggly animator settings, set wiggles/sec to 0. now they will be locked into a random state.
    to animate them from random to ordered, key frame the max amount to go from 100% to 0%, and key frame the min amount to go from -100% to 0%. now they letters should come together from the random state to the ordered state.
    since the wiggly selector effect the position of the letters in both negative and positive directions, you can animate the z position of the text layer (transform>position) to go from beyond/behind the camera to the final position, timing that with the keyframes that you have for the max and min amounts.
    you should have something that resembles the example, continue to modify the settings to get what you need.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
