Activity › Forums › Adobe After Effects › How Is This Done….???
  • Cal Johnson
    August 28, 2006 at 8:23 pm
    Looks pretty straight forward to me as far as the concept goes… All the layers of text are 3D layers, positioned in 3D space, with opacity keyframes to turn them on at the right time. Then the camera is animated so it “follows” the text. Probably was a lot of time consuming work, but you should be able to mimic the effect if you want to.
