Activity Forums Adobe After Effects How is this done?
  • How is this done?
    Posted by Curtoid on April 12, 2007 at 6:21 pm
    How would I go about creating this type of mograph, in which a line animates along a complex 3d path. There are quite a few similar projects that I’ve seen which incorporate pics/video along the path, and then morph into a Title. Any links to tutorials would be appreciated as well.
    https://youtube.com/watch?v=4-8XWdaaG6M
    Thanks in advance.
    Curtoid
    Aharon Rabinowitz replied 19 years, 5 months ago 10 Members · 17 Replies
  • 17 Replies
  • Steve Roberts
    April 12, 2007 at 7:13 pm
    AE paths can’t bend in three dimensions. So complex 3D path = 3D app, not AE. Cinema 4D is usually used for this sort of thing.
  • Aharon Rabinowitz
    April 12, 2007 at 7:31 pm
    Definately one of the most requested effects, but still not possible in AE on a practical level.
    Take a look at this tutorial for info on doing it with Maya and C4D:
    Click Me!!!
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Aharon Rabinowitz
    April 12, 2007 at 7:34 pm
    Click Me!!!
    Aharon Rabinowitz
  • Todd Morgan
    April 12, 2007 at 8:10 pm
    can you not use 3D stroke with camera moves?
    Todd Morgan
    Creative Director
    morgancreative
    http://www.morgancreative.biz
  • Steve Roberts
    April 12, 2007 at 8:21 pm
    Maybe yes, but with a separate stroke/layer for each bend. You can’t make 3D stroke bend in more than one plane in a controlled manner, so you need to split it up, with a single-plane bend for each layer. If that’s not a problem, give it a go. 🙂
  • Danny Princz
    April 12, 2007 at 8:29 pm
    there may be some hope in the not so distant future
    https://shisko.blogspot.com/2007/04/3d-warp-distort-in-after-effects.html
    should be a good NAB this year
    who is that masked man…
  • Blair Mcnaughton
    April 12, 2007 at 9:41 pm
    Could it not be done with some sort of particle generator? Something like this is able to bend in all dimensions. Surely it shouldn’t be too hard to make a rectangular shaped particle instead and have it emit enough times per second to make it look as though it’s a solid line… Then you can just keyframe the emitter.
  • Dflamholc
    April 12, 2007 at 9:47 pm
    THis effect could be easily achieved in ae 6.5 with ECHO effect on a small solid in a pre-comp with 3d switch on and collapse transformation clicked (check tutes here at the cow by Joe Chao about confetti i think) a bit tricky with timing cam movements when projs get complex, but i’ve done it several times. unfortunately there is a bug with the echo effect and collapse transformations in ae7… something I hoped would have been fixed in 7.1 but wasn’t… hopefully fixed in cs3!
    good ot use lights on the collapsed 3d comp to enhance 3d space.
    good luck! cheers /david
  • Blair Mcnaughton
    April 13, 2007 at 12:21 am
    Voila!
    Made using Trapcode Particular and a variation on Andrew Kramer’s tutorial here. This method allows full and easy control over the path, although does require Trapcode Particular which would set you back $299… but that is probably cheaper than buying a completely new 3D application.
  • Ron Lindeboom
    April 13, 2007 at 4:30 am
    Curtoid,
    This is the 4th time you have asked the EXACT same question on the COW forums in the last couple of days. Some are live, others I have shut off to cull the noise.
    When I wrote you regarding this, the email account was bad and so I have killed the “Curtoid” account.
    If you create a new account, please be aware that we watch IPs of problem accounts and will shut-off access from your individual log-in IP if you persist in this kind of thing again.
    Ron Lindeboom
    creativecow.net
