Activity › Forums › Apple Final Cut Pro Legacy › How I’d do this?
  • Shane Ross
    June 21, 2006 at 5:59 pm
    Apple R is for RENDER SECTION. If you have an IN and OUT point set, or clips highlighted. OPTION R is RENDER ALL.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Bret Williams
    June 21, 2006 at 7:29 pm
    Apple R is for renderng either in to out, or selection. Whichever is applicable, with selection taking precedence.
    Option+R renders everything.
    It’ll all there in the sequence menu.
  • Captain Mench
    June 21, 2006 at 8:52 pm
    Apple-R is also a render those things that need rendering at a level I’ve asked you to render…
    ya — so, Check your render settings under your sequence menu. I’ll bet that it is set only to render Red Line and maybe Orange Line material. If you need it to render GREEN line stuff you can tell it to.
    Good luck,
    CaptM
