Activity Forums Adobe After Effects How I do select/isolate an area at a composition for applying effects?
  • How I do select/isolate an area at a composition for applying effects?
    Posted by Kabey1 on September 2, 2007 at 9:15 am
    My questions goes like this: How do I select/isolate an area at a composition or for applying effects?
    For example, if I have some movie with a moon at the upper right corner, and I want to apply some effects to that moon only leaving the rest of the composition as it is. I tried using masks but it didn’t work.
    This is quite urgent.. Any suggestions?
    Thanks alot
    Bill
    Steve Roberts replied 19 years ago 4 Members · 4 Replies
  • Frank Hardie
    September 2, 2007 at 11:31 am
    Duplicate the layer, apply your effects, then use a mask/s to isolate the appropriate area. Depending which effects you apply, you may need to precompose the duplicate layer before masking.
  • Steve Roberts
    September 2, 2007 at 12:11 pm
    Did you try applying the effect to an adjustment layer above the footage, then masking the adjustment layer?
  • Jerry Waters
    September 3, 2007 at 7:38 am
    Along this line, can you create the adjustment layer over just a portion of the composition, and if so, how? Are there some keystrokes or commands like the “b” and “n” to set the composition area?
    Thanks for any incite.
    JerryW
  • Steve Roberts
    September 3, 2007 at 10:57 am
    You could trim the adjustment layer, like any layer …
