Activity › Forums › Apple Final Cut Pro Legacy › How have Timestamp from AVCHD file import into Final Cut Pro
  • How have Timestamp from AVCHD file import into Final Cut Pro
    Posted by Jb Yong on August 15, 2011 at 4:11 am
    I have sony avchd files that I converted into apple pro res 422 LT using final cut pro File and Transfer.
    However the files does not generate time stamp on these file or Start Time.
    I have to mix these avchd files in with Canon 7D files which generates timestamp with Canon EOS plugin for final cut.
    I would like timestamp so I can sort all these files together by timestamp. Unless there is better way of organizing lots of files.
    Shane Ross replied 15 years, 1 month ago 2 Members · 1 Reply
  • Shane Ross
    August 15, 2011 at 6:27 am
    Most AVCHD formats don’t record timecode, so FCP doesn’t look for it. Each clip starts at 00:00:00:00. Some cameras do record timecode…but for some reason FCP 7 and 6 don’t look for it, or don’t care about it. CLIPWRAP 2 will transfer it for you though.
    Shane
