Activity Forums Apple Final Cut Pro Legacy How final cut generate mov file…
  • How final cut generate mov file…
    Posted by Marcelokron on October 6, 2005 at 10:55 pm
    Hi… I’m working in a PC and I have to produce a mov file… What are the settings for appropriate using in Final Cut?
    Lower or Upper field?
    Square pixels???
    any thing more to set?
    Thanks a lot!
    Marcelokron replied 20 years, 11 months ago 2 Members · 4 Replies
  • David Roth weiss
    October 7, 2005 at 12:08 am
    Marcel,
    That all depends on the particular FCP system and what the rest of the material they will be cutting on the timeline with the material that you provide. Are they working with 720×480 DV, or 720×486 BetaSp or DigiBeta???
    DRW
  • Marcelokron
    October 7, 2005 at 2:10 am
    Hi there… I have an AVI file in this format 720×480 DV and I have to sent to a final cut also in DV quality
    Thanks!!
  • David Roth weiss
    October 7, 2005 at 2:32 am
    Marcel,
    That’s easy, just output a QT at standard DV settings, 720×480, lower field dominance, 4:3 aspect ratio, using the Apple DV/DVCPro NTSC codec or animation codec if that is not available on your system.
    Good luck,
    DRW
  • Marcelokron
    October 7, 2005 at 2:36 am
    Thanks!!
    helpe me a lot!!
