Activity › Forums › Creative Community Conversations › How exactly has FCX improved or expedited your workflow?
Dave Jenkins replied 12 years, 11 months ago 26 Members · 78 Replies
Jeremy Garchow
September 30, 2013 at 9:11 pm[Justin Crowell] “Right, I understand that…but I’m really curious as to what that “internal architecture” may be.”
It’s intel’s AVX architecture.
Found by cow user Andrew Richards: https://forums.creativecow.net/readpost/335/38013
Justin Crowell
September 30, 2013 at 9:21 pmAh, thank you, Walter! That makes sense. I use a hackintosh i7 at home and a Pro at the studio, and I always forget that not all Sandy Bridges are made equal. I also wasn’t quite aware of this slightly esoteric difference between the xeons and the i7s.
This makes me want the trash can/jet engine/spaceship all the more, now!
Editor, Producer, DP
JustinCrowell.com -
Jeremy Garchow
September 30, 2013 at 9:27 pm[Justin Crowell] “Ah, thank you, Walter!”
Sure, Freddy!
Justin Crowell
September 30, 2013 at 9:37 pmShoot, sorry about that, Jeremy! I probably made that mistake because of some internal architecture issue. Stupid outdated brain…
JustinCrowell.com -
Jeremy Garchow
September 30, 2013 at 9:42 pm[Justin Crowell] “Shoot, sorry about that, Jeremy! I probably made that mistake because of some internal architecture issue. Stupid outdated brain…”
HA!
I know exactly how you feel.
David Powell
September 30, 2013 at 11:12 pmI am similiar with how I use shortcuts. My Avid Keyboard is very customized and I try and keep my FCP and FCPX keyboard as similar as possible. That being said, Avid is mode based which makes the keyboard more efficient imo, so that when you are in CC mode or Multicam mode you can switch from 4 up to 9 up and the keyboard setup itself will change. Other NLEs require more command programming. The X keyboard is extremely customizable but it is an extremely Mouse driven program. The trim tools aren’t as slick as Avid or Premiere CC. I have the transport on the left hand side and keep one hand on the mouse at all time, funny enough, something I learned from reading “Avid Agility” though I didn’t find it as helpful in Avid as I do in FCPX.
Once you start stacking vid clips, there are no shortcuts to control which layer of video you want to affect. Its something I hope Apple changes.
Oliver Peters
October 1, 2013 at 12:18 am[David Powell] “The trim tools aren’t as slick as Avid or Premiere CC.”
True, but they are completely keyboard controllable. Use the arrow keys to go forward or backward to the next or previous cut. Then backslash selects the cut to trim. Left bracket, right bracket or backslash toggle between left/right edges or center trims. Comma, period or numerical entries control the trim value. Shift-slash plays around the cut.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Walter Soyka
October 1, 2013 at 1:23 am[Justin Crowell] “Ah, thank you, Walter!”
[Jeremy Garchow] “Sure, Freddy!”
There are worse names you could have been called…
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Jeremy Garchow
October 1, 2013 at 1:46 am[Walter Soyka] “There are worse names you could have been called…”
I was honored, actually.
Justin Crowell
October 1, 2013 at 2:37 pmI can’t think of anything clever to respond to all this with. But the government shutdown, so maybe I should just take the day off, anyway.
JustinCrowell.com
