Activity Forums Adobe Premiere Pro How does slow motion works in 1.5?
  • How does slow motion works in 1.5?
    Posted by Uwe Lansing on July 6, 2005 at 4:17 am
    can anybody explain the method of slomo in 1.5? Is it the same way like in After effects with blending frames (building new frames between or only adding the same frame once again…)?
    What about the very expansive Plugin Twixtor? Is there another way to create a very good slomo?
    Thank you
    Uwe
    Mike Velte replied 21 years, 2 months ago 4 Members · 5 Replies
  • Mike Velte
    July 6, 2005 at 11:32 am
    Pro uses the same slo mo engine as AE…works very well at most settings.
  • Creig Bryan
    July 6, 2005 at 1:36 pm
    Hunh? I thought AE used Time Remapping, nonexistent in PPro…
    Keep Smiling
  • Steven L. gotz
    July 6, 2005 at 3:16 pm
    AE has time remapping, but it also has the abikity to merely change the duration like in PPro.
  • Uwe Lansing
    July 6, 2005 at 7:45 pm
    Thank You. Does APP (AE) works with Interpolation (building new frames)?
  • Mike Velte
    July 7, 2005 at 11:09 am
    Pro does create new frames…you can advance thru a slo mo clip frame by frame…no dups.
