Activity Forums Adobe Premiere Pro How does one determine the Pixel Aspect Ratio of a clip?
  • How does one determine the Pixel Aspect Ratio of a clip?
    Posted by John Rich on October 18, 2011 at 12:59 am
    Using a 6 core AMD with 16 gb ram and a Program disk with a RAID0 (2TB) and Prem Pro CS5, WIN 7.
    I downsized a 1920×1080 cineform master file to 720×480 (PAR 1.2) using cineform’s utility HDLINK.
    When I imported the downsized file into PP it showed the PAR as .9.
    The characters looked “thin” so I did File – Modify- Interpret footage and set the PAR to 1.2 and it seems to be normal.
    This made me wonder if there was a way to find out what the PAR is. I used to use Gspot with older computer and xp, but the Gspot web site doesn’t mention Win7 being supported.
    Mediainfo shows “display aspect ratio” which is just the width/height and not the PAR.
    I was wondering if the actual PAR is listed somewhere correctly or if there is another utility I could try?
    Thanks in advance,
    John Rich
    John Rich replied 14 years, 11 months ago 2 Members · 2 Replies
  • Jeff Pulera
    October 18, 2011 at 3:18 pm
    Hi John,
    I installed G-spot on my Windows 7 machine, works fine
    Jeff Pulera
  • John Rich
    October 18, 2011 at 6:39 pm
    Thanks Jeff. It works for me too.
    John
    JOHNR
