How Does One Achieve The Highest Possible Quality SD DVD
Hello All,
This is my first post EVER because after many years of reading your posts (which alway give me new direction), I’ve decided it’s time to get a complete answer to my long time quest… achieving the highest quality SD DV video DVD possible.
I own a small production company that specializes in creating DVDs of theatrical events. The extreme lighting conditions are challenging to say the least and the backgrounds in my final DVDs are always full of artifacts I’d rather not see with the subjects never quite as clear as they are in the original footage.
I shoot with 2 Canon GL2s and have recently hired a camera man who uses a new professional grade Sony HD camera. He uses the SD setting for my jobs, and we both shoot using the 16:9 setting (the one that makes the footage look squashed/compressed when viewed on a 3:4 monitor). I edit using FCP, always send the resulting sequence to Apple Compressor (which I know how to use very well at this point), and author the DVDs in DVDSP.
Until I added this third camera, I hadn’t even thought about using Apple Color, but due to the color disparity I’d been experiencing between the two types of cameras, I decided it might be worth some investigation. But now that I’ve read the entire Apple Color manual, I find myself, once again, back at the capturing stage, wondering if there might be something I’ve been missing all this time; some setting that might help my final output be rid of the annoying artifacts that continue to annoy my eye and who’s fix eludes me!
I’ve been capturing via firewire using the FCP preset DV NTSC 48 kHz Anamorphic. Is there a better way or setting? If so…
What should my Frame Size and Aspect Ratio settings be? And my QuickTime Video Settings… What should I choose for my digitizer, compressor, quality, and FPS settings? Is there anything under the advanced menu that I should be changing? Do I check “Remove Advanced Pulldown and/or Duplicate Frames…” and “High Quality Play Through”?
OR…
Could the problem be with my sequence settings?
Again, what are the best settings for Frame Size, Aspect Ratio, Filed Dominance, Editing Timebase, and Timecode Rate? And the Quick Time Settings for Compressor, and Quality? Anything I should be aware of in the Advanced tab? And what about under the Video Processing Tab?
OR…
Is Apple Color the answer to all my problems?
I edit using the multi clip feature in FCP which I understand from reading here on CC can cause some issues in Color. After reading several posts, however, it seems that if I collapse the sequence and use Media Manager to send it to Color, I should be in good shape.
I guess I’m just tired of working so hard on a project, doing a great job on the edit, only to have the video quality be less than adequate on the final DVD. Of course the parents don’t mind, they are just glad to have a decent quality memento of their child’s performance. But I am positive there must be something I can do to improve the final quality of my product.
Geez! I guess I shouldn’t have waited so long to post… Seems I had quite a bit to ask after all!!
Thanks for any help you can send my way.
I look forward to your words of wisdom!
Lisa Laughbaum
Laughing Tree Productions
http://www.LaughingTreeProductions.com
