Activity › Forums › Apple Final Cut Pro Legacy › How Does It Know?
  • How Does It Know?
    Posted by Jeff Coleman on October 15, 2007 at 3:04 pm
    I’ve created a couple of short 1920×1080, 29.97pfs, QT movies in AE 8.
    When I open them in QuickTime Player it confirms the frame rate is 29.97.
    However, when I import them into FCP 6, it says the frame rate is 23.98. (and FCP wants to change my 29.97 sequence to 23.98 to match).
    How can I get FCP to import these movies at the correct frame rate?
    Intel Octobox 9GB RAM
    OS 10.4.10
    FCS 2
    QT 7.2
    AE 8
    John Pale replied 18 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mark Maness
    October 15, 2007 at 3:21 pm
    What is the video compressor that you are using? Animation, ProRes422, etc.?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Jeff Coleman
    October 15, 2007 at 6:55 pm
    apple 10 bit Uncompressed
  • Walter Biscardi
    October 15, 2007 at 7:00 pm
    Can you by any chance override the frame rate in the FCP Browser?
    And you definitely did set up a 29.97 comp in AE, correct?
    It is odd that QT player sees it correctly, but not FCP.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • John Pale
    October 15, 2007 at 8:35 pm
    Open the problem clip in Cinema Tools. Then conform the clip to 29.97fps.
    The conform is pretty instantaneous. It doesn’t actually do anything, as the clip is actually 29.97fps…it just repairs the incorrect frame rate flag that is tripping up Final Cut Pro.
    This has worked for me on several occasions.
  • Jeff Coleman
    October 15, 2007 at 9:51 pm
    Cinema Tools thinks the frame rate is 29.97, but I told it to conform to 29.97 anyway and reimported into FCP and voila! that worked!
    Thanks John Pale!
    Does that make it a QT issue?
  • Jeff Coleman
    October 15, 2007 at 9:55 pm
    Can’t override the frame rate in the FCP Browser.
    Definitely 29.97 comp in AE
    odd, indeed
  • John Pale
    October 16, 2007 at 1:48 pm
    [Countdown] “Does that make it a QT issue? “
    I think its an intermittent quicktime bug with AE. I have seen it crop up a few times.
    Cinema Tools seems to be the only way to fix it.
