Activity › Forums › Adobe After Effects › how does intelacing work with interlaced videos?
  • how does intelacing work with interlaced videos?
    Posted by Jeremy Webb on June 12, 2005 at 9:27 pm
    if i am working on a project with ntsc video – lower field first 29.97 fps, and then add a image sequence, and export as an image sequence, how will interlacing work with that? will the final image sequence have 60 images per second (one for each field)?
    Stephen Botting replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Webb
    June 12, 2005 at 9:42 pm
    sorry the title should read: how does intelacing work with IMAGE SEQUENCES?
  • Stephen Botting
    June 14, 2005 at 12:11 am
    I havn’t got it in front of me, but from memory it dosn’t create a file for each field, AE will only create 1 file per frame.
    So you should still import the image sequence at the same frame rate. 30 in your case.
    But you can right click on the image sequence in the project window and select interperate footage to change frame rates and field orders if you need to.
    Stephen
    Stephen Botting
    stephen@43south.co.nz
    https://www.43south.co.nz
