How does Hollywood make 2 hour DVD’s with such good quality? Can I?
Posted by Larry Watts on April 29, 2005 at 5:09 pmWhere is the best place to find the scoop on how Hollywood can make 2 hour HIGH QUALITY DVD’s?
I have to make a 96 minute DVD. CAn this be done with reasonable quality?
How?
Larry
Edward Troxel replied 21 years, 5 months ago 3 Members · 5 Replies -
Gary Kleiner
April 29, 2005 at 5:16 pmFirst of all, film is WAY higher resolution than video, so the source material is higher quality to start with.
Second, there are wole departments filled with people whose only job is to tweak the encoding for each individual scene.
Third, a pressed (replicated) DVD can hold more information than a burned one. Thus, the overhead for file size is higher.
Can you make a high quality 96 minute DVD? Certainly. Do you have a high quality master?
Larry Watts
April 29, 2005 at 5:48 pmGary,
My “high Quality” master is on my hard drive.
I’m limited to the DVD Burner’s capabilities, therefore…
in my first step I’ve already degraded the master.I could output to tape and outsource burning to DVD, but to whom?
If burners hold less than replicated DVD’s what does “Hollywood” use as a master for the replicator?
Am I missing something?
Larry
Gary Kleiner
April 29, 2005 at 7:20 pm -
Larry Watts
April 29, 2005 at 8:06 pmWhen I talked with Vegas tech support it sounded like any additonal compression lower than 8 mbps
would show serious degradation.The sample that finished just 20 minutes looked excelent, however.
DVDA also showed red flags on the video at lower compression.
Larry Watts
LSW
Edward Troxel
April 29, 2005 at 8:50 pm
