Activity Forums Apple Final Cut Pro Legacy How does AVHCD mix w/HDV in FCP6?
  • How does AVHCD mix w/HDV in FCP6?
    Posted by Julie Hill on July 9, 2009 at 5:36 am
    I know nothing about AVHCD but I think I’ve heard that it doesn’t edit well in FCP. I want to hire a shooter who’s camera shoots in this codec but my other shooters will be on Sony’s shooting HDV. Can i mix them on one timeline in FCP? What about field orders in 1080 60i? urgh.
    Russell Lasson replied 17 years, 1 month ago 3 Members · 2 Replies
  • Shane Ross
    July 9, 2009 at 6:20 am
    Well, FCP doesn’t edit AVCHD natively, it imports it as AIC or ProRes. So it immediately is converted into an I-Frame format. If you convert HDV to ProRes then you are all set! Best to convert everything to an uniform codec anyway.
    Shane
  • Russell Lasson
    July 14, 2009 at 11:45 pm
    Shane’s right. Converting to ProRes is a great way to go. I also suggest keeping all of the original source files from the camera and backing them up. Use reel names too for each time you copy stuff from the camera. That way, if you need to go back to bring in some new footage, you can.
    Also, try to shoot the same frame rates if you can. Most HDV and AVCHD will be 60i, so it shouldn’t be a problem unless you’ve shot at some other frame rate.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
