Activity › Forums › VEGAS Pro › How does a DVD with ACVHD compare to a Blu Ray
  • How does a DVD with ACVHD compare to a Blu Ray
    Posted by Greg Barringer on November 30, 2008 at 10:31 pm
    I was able to burn a DVD-R using Blu Ray from Vegas. The Sony Blu Ray player recognizes it as ACVHD-DVDR and it plays in 1080p. Would there be an improvement in quality if I used a Blu Ray burner?
    David Shirey replied 17 years, 10 months ago 5 Members · 14 Replies
  • 14 Replies
  • John Rofrano
    December 1, 2008 at 3:57 pm
    No, you just get more capacity. Burning is essentially just a file transfer of the data. The quality would be the same.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Danny Hays
    December 1, 2008 at 4:39 pm
    So I can burn blu Ray rendered files to a regular DVD and play it on a Blu Ray player? I didn’t know this. Thanks John. Danny Hays
  • John Rofrano
    December 1, 2008 at 4:45 pm
    Yes, you are just limited to the capacity of the disc which is about 20 minutes. The physical DVD media was never meant to play back such high bitrate files so it is unknown if over time the disc will become unreliable but they do seem to play fine.
    ~jr
  • Greg Barringer
    December 1, 2008 at 7:30 pm
  • Terry Esslinger
    December 1, 2008 at 7:33 pm
    Lets ee if I have this straight: I can take HDV video from my F1 and render it using one of the BluRay templates (don’t know which one except that it probably should be NTSC) Then burn it to a standard DVD-R (not a bluRay disc) using a BluRay burner (not a standard burner)and it should play on a BluRay player (ie PS3)But I am limited to about 20 minutes and there is some question of longevity.? What program do you burn it with?
  • John Rofrano
    December 1, 2008 at 10:17 pm
    Terry, It’s even better than that. You don’t need a Blu-ray burner at all. Just a Blu-ray player / PS3. You can use your regular DVD burner to burn a 20 minute Blu-ray image onto a standard DVD media disc. You do this right from within Vegas from the timeline with:
    Tools | Burn Disc | Blu-ray Disc…
    ~jr
  • Greg Barringer
    December 1, 2008 at 10:30 pm
    Thanks for all the comments, the slideshow is a better quality than I ever expected.
    I burned Blu Ray to a standard DVD directly from Vegas like John said. I played it in a Sony BDP-S550.
  • Terry Esslinger
    December 1, 2008 at 10:32 pm
    John,
    Just a little bit more on this please. You don’t even have to render the time line to anything.? I assume tha time line needs to be m2t or native HDV. What if you have made editing changes (transitions, color correcting etc). Thanks for your time.
  • Greg Barringer
    December 1, 2008 at 10:38 pm
    Rendering and burning will all be completed. Choose 1920×1080 60i and leave the rest a default.
  • Terry Esslinger
    December 1, 2008 at 10:46 pm
    I’ll give it a try as soon as I get a chance.
