Activity Forums Apple Final Cut Pro Legacy How do you use the notch filter in FCP? I don’t see a gain control. Only frequency and Q.
  • Jerry Hofmann
    August 8, 2005 at 1:07 pm
    The Q slider determines the range of the effect, and the frequency slider determines, well, the center of that range of frequency affected. The idea is that a range of frequency is notched out completely so you wouldn’t need a gain slider for that.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
