Activity Forums Adobe After Effects Expressions How do you turn off the text effects with expressions?
  • Mylenium
    September 27, 2006 at 6:04 am
    Split the layer and remove the expression. Other than that you can add sliders to expressions in most cases and by animating the slider range towards zero you can effectively disable them. In your case you’d need to add a slider expression control and use something like this:
    amplitude=effect(“Amplitude”)(“Slider”)
    wiggle(f,amplitude)
    Mylenium
    [Pour Myl
