Activity › Forums › Panasonic Cameras › How do you sync two Panasonic VX100s? Help!
  • How do you sync two Panasonic VX100s? Help!
    Posted by Charle Goucher on March 4, 2008 at 1:20 pm
    whats the best way was to sync your footage?
    i’m recording with two panasonic vx100’s.
    could someone give me an in-detailed description/walkthough?
    i heard you can do it though the cameras? thanks!
    Steve Wargo replied 18 years, 6 months ago 3 Members · 2 Replies
  • Tim Scarpino
    March 4, 2008 at 3:05 pm
    If you’re talking timecode, you can do do it by using the remote control and having the DVXs side-by-side.
    Be sure the timecode generator is set to “free” on both DVX’s and that they are BOTH set to either Drop Frame or Non-Drop Frame.
    Using the Remote Control, set your desired timecode.
    All should be well, though I would check from time to time to insure they are still in “sync”.
    Tim Scarpino
    Tim Scarpino
  • Steve Wargo
    March 6, 2008 at 4:43 am
    We use a regular flash camera.
    Rewind the tape in both cameras even if it’s new.
    Set the TC to Record Run.
    Start both cameras with a remote.
    Let them run for 20 seconds.
    Snap a flash on something that both cameras can see.
    In post, line up the flash.
    Your TC should be pretty close
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
